i reinstalled windows 10 and no longer connect to internet
Windows 1x on Thinkpads
derwen
#1 Post by derwen » Sun Dec 22, 2024 8:57 am
I have t14 gen 2 AMD and just reinstalled windows 10 from linuks mint and propably did delete some wrong partition becose when i reinstaled windows 10 i no longer conect to Wifi and ethernet i apperently have good drivers but they doesn't work can someone schow/write/recommend someone what i schould do what to install what uninstall what change because I don't really know what to do ?
Re: i reinstalled windows 10 and no longer connect to internet
#2 Post by dr_st » Sun Dec 22, 2024 9:07 am
Maybe you accidentally enabled 'airplane mode'?
derwen
#3 Post by derwen » Sun Dec 22, 2024 11:30 am
no nothing works even if i restore windows from usb istall 11 from the start and a the pilot mode is disabled sorry for late reply
#4 Post by dr_st » Sun Dec 22, 2024 12:58 pm
This sounds very weird.
If you run Linux from a live USB stick - does network connectivity work?
Did you somehow disable the networking devices in the BIOS?
derwen
#5 Post by derwen » Sun Dec 22, 2024 2:42 pm
i will try once again in bios i put everythink in factory setting
derwen
#6 Post by derwen » Sun Dec 22, 2024 4:31 pm
i put mint again on t14 and wifi is working no fuss no muss but ethernet is still not working but i must probably download drivers
755cdxd
#7 Post by 755cdxd » Sun Dec 22, 2024 9:00 pm
Linux Mint by default installs some drivers for NIC's and GPU's. Are you sure your windows installation had required drivers? I doubt Windows would carry hundreds of drivers for all the available hardware out there. :wink:
What wifi card do you have? If you still have linux installed run "lspci | grep -i net" in terminal and show us.
Chances are you have too manually install driver for this card.
t60, t480
Install libreboot now!
derwen
#8 Post by derwen » Mon Dec 23, 2024 11:04 am
SOLVED
Thanks everyone who have took the time to think and respond to my problem
I feel a little stupid becose I downloaded a wrong drivers and expected them to work now i have repair everything and all is good
Once again thank you for your help and have a good rest
Return to “Windows 10/11/etc.”
