X200s WiFi EXTREMELY slow
I recently got an X200s, and I'm getting really slow network speeds. I swapped out the card for one I had in another laptop that I know works fine, and it's still bad. I did a speed test, and got less than 0.5 Mbps download and upload. What could be causing this?
(Un)professional laptop breaker, semi-professional sysadmin at ~vern
380Z, A31 (w/ A31p lid assembly)
R400, R500
T60, T400, T400s, T500, W500
X30 2672-4B7, X60, X200s, X200 Tablet
Z61m
s30
G50
R400, R500
Z61m
s30
G50
Re: X200s WiFi EXTREMELY slow
Try updating your drivers.
Thinkpads
R51 1829-W1C 2GB RAM
R500 2716-RY6 8GB RAM
T520i 4239-47U, 16GB RAM
T530 RIP
P15 G2 20YR 16GB RAM
SK-8835 Ultranav keyboard Japanese layout
T530 RIP
I can Assure you that the issue is not drivers.
R400, R500
Z61m
s30
G50
R400, R500
Z61m
s30
G50
possibly the card has gone bad. this happens sometimes.
you can try to replace it with a replacement card and see if it gets better.
personally i encountered some failures of Intel 5100 few years back when everyone in my household daily drove T500, contemporary to X200s. i would usually replace them with Intel Advanced N 6205 since i had a lot of those as spares. these cards are dirt cheap. but this swap requires a whitelist-removed modified BIOS for T500 which I had/have since no T500 ever came with Advanced N 6205, it is from newer models.
X200s as with most ThinkPads has a whitelist on the WLAN slot so if you cannot source an official Lenovo Intel 5100 or 5300 WLAN card, you would have to flash a modified BIOS to replace the card with a non-period correct and non-OEM card.
This modified BIOS should work. https://www.mediafire.com/file/2ef354zi ... L.rar/file
AFAIK X200 and X200s are the same as far as BIOS is concerned. here's an official Lenovo readme for the official version of that BIOS, supporting as such "Support models ThinkPad X200, X200s" : https://download.lenovo.com/ibmdl/pub/p ... uj48us.txt
you can also go to bestbuy and buy a USB-based WLAN, and that will just work.
sent from my iPhone
I already tried replacing the card, as I said in my original post, nothing changed.
R400, R500
Z61m
s30
G50
R400, R500
Z61m
s30
G50
apologies. i must have skipped over that. my bad.
something could be wrong with the access point or the Operating System.
how close can you get to the access point? is speed still crappy right next to it?
in my experience with X-series my X230 has goddawful wireless reception, every other laptop I own is better than that X-series, i know it's not X200s but it's the closest I've got to one.
sent from my iPhone
Got like a meter away from the router, was still slow. Also, I have an X200 Tablet that works perfectly fine with an identical OS config (I use a declarative system).
R400, R500
Z61m
s30
G50
R400, R500
Z61m
s30
G50
i wonder if the antennas and/or their cabling have broken or become damaged somehow.
best of luck figuring this out.
sent from my iPhone
Dirt/bad contacts in the wifi-switch on the left?
This is my suspicion as well. I've personally seen an Intel 4965AGN detect WiFi signals (though unable to actually connect to routers) even without any antenna attached. A cable with a break somewhere in the middle would still work as an antenna, albeit poorly.
The other suspect is software, which can be verified by running a different operating system--one reason I carry around a portable SSD with Linux installed.
W520 and WiFi connection speed issue
by jdwis » Sat Nov 01, 2025 7:11 am » in ThinkPad W500/W510/W520 and W700/W701 Series - 8 Replies
- 24679 Views
Last post by jdwis
Wed Nov 12, 2025 11:57 am
Can't enter wifi-Password in a hotel or anywhere else?
by RealBlackStuff » Mon Dec 22, 2025 2:31 am » in Windows 10/11/etc. - 2 Replies
- 4187 Views
Last post by Scorpion8
Mon Dec 22, 2025 6:38 pm
XP T60 randomly stops seeing my wifi network.
by Glaurung-quena » Thu Jan 29, 2026 5:30 pm » in ThinkPad T60/T61 Series - 5 Replies
- 4962 Views
Last post by Glaurung-quena
Sat Jan 31, 2026 10:06 am
