Sensor just lives its own life. Connecting and disconnecting all the time. I did look at the cable under microscope, appears to be alright. I did continuity check just in case, also fine. I looked over the sensor, no shorts. Went ahead and reflowed the main chip, just heat it and touch it, no reball. The sensor I did reball. Still, same behavior. Kinda wondering what to replace, the sensor or the cable, at this point. 10 years or so back I did replace upper plastic piece with sensor and cable together. Nowadays market place is kinda poor on parts. For example, cable on ali kinda don't look like the one I have, not sure if it will even work.
