T480 - Internal Battery discharge issue
T430-T495, T530-T590 Series
timtakpad
#1 Post by timtakpad » Sun Apr 27, 2025 3:56 pm
I wonder if T480 - Internal Battery discharge issue/fiasco still exist?
I've had been burnt with this issue not too long after I purchased T480 6 years ago. I did replace the original internal battery which was reported as failed after that but the replaced one (OEM) failed in a short time frame. At the time I came to know that the "Power Bridge" has issue probably the firmware issue. I still have the original battery. I wonder if Lenovo ever fixed this issue perhaps via a BIOS update or is this issue still exist? I'm not sure if there is a way to revive the batteries I've but I can buy one from Ebay . However I don't want to buy it to deal with the failure again.
I came across TLP and tp-smapi but trying to understand these and figure out what I need to do to fix if there is one.
Please advise,
rumbero
Re: T480 - Internal Battery discharge issue
#2 Post by rumbero » Sun Apr 27, 2025 4:04 pm
What does this yet unexplained issue/fiasco consist of?
timtakpad
#3 Post by timtakpad » Sun Apr 27, 2025 4:10 pm
Well, the issue was - it discharges the internal battery first and then the external one. In my case, it discharged the internal battery below the safe threshold and reported it as failed. I replaced the original batter with another genuine battery thereafter but the same thing happened to it as well.
Users browsing this forum: No registered users and 205 guests
