T540p Custom Bios
T430-T495, T530-T590 Series
averagenokiauser
T540p Custom Bios
#1 Post by averagenokiauser » Tue May 06, 2025 11:19 am
Hello, are there any custom bioses available for T540p? With custom i mean with no whitelist or one that has advanced options.
Re: T540p Custom Bios
#2 Post by RealBlackStuff » Tue May 06, 2025 12:04 pm
The only ones I've ever seen are here and here.
averagenokiauser
#3 Post by averagenokiauser » Fri Jul 11, 2025 10:15 am
Thanks for sending these. I followed the second guide and everything went well. I also used me_cleaner and that works perfectly too in case anyone wants to disable that on T540p.
jruschme
#4 Post by jruschme » Fri Jul 11, 2025 7:04 pm
I thought that T5xx BIOSes didn't have a whitelist.
JR
Current: T440p|T440s|T450|T550|S230u|E431|X300
Former: T20|T22|600E
independent
#5 Post by independent » Sun Jul 13, 2025 3:45 pm
Can you detail what me_cleaner settings you used. It will be helpful to future readers. If you are unsure, just leave the me_cleaner switch you used. Thank you.
Freshman GNU/Linux member since 2007!
averagenokiauser
#6 Post by averagenokiauser » Thu Jul 17, 2025 5:51 am
For me_cleaner the command i ran was
python me_cleaner.py -S -O modified_image.bin original_dump.bin
This is in the external flashing documentation and i didn't change anything. Keep in mind that the chip that contains ME is the one closer to the SIM card slot and the one further away is the BIOS chip.
Users browsing this forum: No registered users and 83 guests
