Yoga 7i Pro not booting/turning on
Discuss the ThinkPad-branded Yoga
SpartanJack17
#1 Post by SpartanJack17 » Fri May 30, 2025 1:58 am
My Lenovo Yoga 7i Pro (2023 model) has just stopped turning on, the power button flashes a couple of times when pressed but it won't actually turn on. The keyboard backlight and fans don't engage so it's not just a display issue, and this happens both connected and disconnected from the charger. I've already tried opening it up and can't see anything glaringly wrong (no loose connectors etc), and tried disconnecting the battery for a while to see if that'd cause a hard reset.
Re: Yoga 7i Pro not booting/turning on
#2 Post by RealBlackStuff » Fri May 30, 2025 2:10 am
SpartanJack17
#3 Post by SpartanJack17 » Fri May 30, 2025 7:34 am
It's not any of these, I've already tried all these steps plus a bit more.
bixo
#4 Post by bixo » Wed Jun 04, 2025 11:11 am
When you disconnected the battery, did you disconnected the BIOS coin cell?
SpartanJack17
#5 Post by SpartanJack17 » Thu Jun 05, 2025 4:49 pm
I didn't, I'm away right now but I'll try that when I get back.
Unless it doesn't have one, I think some laptops just use the laptop battery for that.
Return to “ThinkPad Yoga”
