T530 Blu-ray Drive recommendations?
T430-T495, T530-T590 Series
Everyday_Normal_Engineer
#1 Post by Everyday_Normal_Engineer » Fri May 30, 2025 9:11 pm
Hey DVD drive is dying so looking to swap it for a Blu-Ray drive either OEM or maybe another manufacture? I thought some external USB drives are just laptop drives in enclosures also. Appreciate any recommendations!
kfzhu1229
Re: T530 Blu-ray Drive recommendations?
#2 Post by kfzhu1229 » Sat May 31, 2025 10:06 am
T530 optical drive is just any 12.7mm SATA laptop optical drive inside some mounting brackets. You can also replace it with a blu-ray drive in exactly the same manner
These SATA blu-ray drives on ebay are neither cheap nor overly expensive. But if you specifically search for a factory Ultrabay option with blu-ray already inside, then you might have a hard time finding it.
I do have a number of spare 12.7mm Blu-ray BD-ROM as well as BD-RE drives I can sell, but I suggest you look up on ebay first.
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
Users browsing this forum: No registered users and 79 guests
