Hi there,
I'm new here so I'm hoping that this post is going in the correct area?... Anyways, I just wanting to know whether anyone has had success in updating their Intel 4965AGN Wi-Fi card to a later generation card? It seems that I may need to update this card due to the router that I'm using and iPhone model that I'm using. I have posted a couple of questions on the Lenovo forum site, but haven't really got much feedback so I thought I might try here...
The links for my concern are here:
https://forums.lenovo.com/t5/ThinkPad-T ... -p/5364921
https://forums.lenovo.com/t5/ThinkPad-L ... -p/5380044
Basically, I can just hook up a cable from the router to the ThinkPad as that seems to work at full Gb speeds but just want to have the ability to hook up to Wi-Fi if need be, at full 300+ speeds depending on Wi-Fi card that can be installed into the ThinkPad.... on a XP setup or even Solaris 10/11... no later version of windows, but later versions of Solaris may happen
Updating the R61 Intel 4965AGN wifi card
titang4ppc
Re: Updating the R61 Intel 4965AGN wifi card
Welcome to the Thinkpads.com forum.
Don't worry, you're in the right section.
To answer your question: the problem with the R61 (and various Thinkpad models across many generations) is a BIOS whitelist that prevents you from installing non-authorized PCIe WiFi cards. Good thing though, is that there is a modified BIOS that has the WiFi check disabled (or skipped)-- see: https://www.thinkwiki.org/wiki/Middleton%27s_BIOS. Do make sure that you download the correct modified BIOS for your R61.
From there you're free to install any card that will fit in the mini-PCIe slot.
- 1 Replies
- 5439 Views
Wed Oct 22, 2025 12:01 pm
Ideas to improve R61 which has been Middleton'ed questions...
by titang4ppc » Thu Feb 26, 2026 8:27 pm » in ThinkPad R, A, G and Z Series - 0 Replies
- 2595 Views
Last post by titang4ppc
W520 and WiFi connection speed issue
by jdwis » Sat Nov 01, 2025 7:11 am » in ThinkPad W500/W510/W520 and W700/W701 Series - 8 Replies
- 24679 Views
Last post by jdwis
Wed Nov 12, 2025 11:57 am
Can't enter wifi-Password in a hotel or anywhere else?
by RealBlackStuff » Mon Dec 22, 2025 2:31 am » in Windows 10/11/etc. - 2 Replies
- 4187 Views
Last post by Scorpion8
Mon Dec 22, 2025 6:38 pm
