My child lost the “O” key from my old ThinkPad X1 Carbon (likely a first-generation model). I had given it to her to start learning coding on Ubuntu this summer.
I’m looking for a trusted source where I can purchase just a single replacement key.
Thank you!
where can i find keys for X1 Carbon?
Bashar
Bashar Al-Abdulhadi
Re: where can i find keys for X1 Carbon?
You need to tell us the exact model (e.g. 3443, 20A7, 20BS, etc.) and Gen (1, 2, 3, etc.) of your laptop and if the keyboard is backlit or not.
Language layout is irrelevant in your case.
If you can't tell us, you'll need to open it up first to find out exactly what the keyboard P/N or FRU is.
That is printed on the bottom of the keyboard itself.
There are a few sellers on eBay, but you need to match the mounting system to their offerings. I found an "R" key and mount for my X1 Carbon 4th Gen from an eBay seller, and they worked with me to make sure I had the right mount identified. Fits and works perfectly.
T490/495/E14 and X1 Carbon user.
Pain heals, chicks dig scars, glory .... lasts forever.
Glaurung-quena
Ebay is one source, another is https://laptopkey.com/
Need keys: IBM Dock II 2877
by crab_rangoon » Sat Nov 08, 2025 2:44 pm » in Thinkpad - General HARDWARE/SOFTWARE questions - 5 Replies
- 8598 Views
Last post by TuuS
Fri Mar 27, 2026 2:01 pm
Looking for X201 replacement keys/domes and 3mm stem to 4mm adapter.
by ThinkIsaac » Mon Dec 15, 2025 4:17 pm » in ThinkPad X200/X201/X220 and X300/X301 Series - 0 Replies
- 4974 Views
Last post by ThinkIsaac
- 13880 Views
Last post by Scorpion8
Wed Nov 19, 2025 4:42 pm
- 11209 Views
Last post by dcfbf
Wed Jan 21, 2026 2:32 pm
Users browsing this forum: No registered users and 59 guests
