T 14 gen2 and Ultra Dock type 40AJ
2020 New name Series after T430-T490 / T530-T590
CeeDee
#1 Post by CeeDee » Thu Jul 17, 2025 9:35 pm
I’m having a problem getting video from the HDMI port on the dock to my Samsung M7 32” monitor. I have tried several different cables to no avail. It works if I use the port on the TP instead of the dock but then I only get HD res not UHD. I believe there is a known problem with USB-3 in this setup but not with hdmi.
Anyone experienced this or have any ideas please.
Regards
Colin D.
T-14 gen2 I7 32gb mem 1tb ssd
past: 600x T-23 T-30 S-30 T-41 X-32 T-60 T60p
____________________________
"Wherever you go, there you are!"
Re: T 14 gen2 and Ultra Dock type 40AJ
#2 Post by axur-delmeria » Fri Jul 18, 2025 8:30 pm
I don't have a 40AJ dock, but you're saying that the laptop's HDMI port only gives you 1920x1080 at best? Check the BIOS settings and see if the HDMI port is set to "2.0".
CeeDee
#3 Post by CeeDee » Fri Jul 18, 2025 9:41 pm
Thank you, I will check the bios tomorrow.
Regards
Colin D.
CeeDee
#4 Post by CeeDee » Sat Jul 19, 2025 3:28 pm
@axur-delmeria On my T14 There is no option for HDMI in my bios only Display; with, Boot Display, Boot Time ex. and video memory.
Regards
Colin D.
Return to “Thinkpad T14/T15/T16”
