My friend recently got a T520 with the Nvidia DGPU in it and he wants to upgrade the cpu.
I have a dead W530 with a working i7 3740qm.
It seems all coreboot does for the T520 is bring support for the newer integrated graphics.
He doesn't need this support since he has the DGPU and the cpu pins should be the same between generations.
If he only uses the dgpu, can Ivybridge work on T520 without coreboot?
If it doesn't, I won't need to disassemble the W530 and he'll just use sandy bridge.
Side note: he doesn't want to coreboot because it needs the chip flasher that he doesn't want to buy.
Is Coreboot required to install Ivy Bridge CPU in T520 with dedicated graphics?
dcfbf
Current Dailies: X1C6, P71
Re: Is Coreboot required to install Ivy Bridge CPU in T520 with dedicated graphics?
IIRC Coreboot is needed for Ivy Bridge on a T420/T520/W520, period.
IMO if your friend uses Windows, then Coreboot is not a good idea due to an incomplete ACPI implementation. I dunno if that's been fixed.
ThinkPad T520 coreboot
by mcq » Wed Apr 08, 2026 10:27 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 0 Replies
- 491 Views
Last post by mcq
Replacing motherboard - is exact match required?
by Thinkpad2024 » Thu Nov 06, 2025 5:04 pm » in Thinkpad AMD-Ryzen - 2 Replies
- 8926 Views
Last post by Scorpion8
Fri Nov 07, 2025 6:08 pm
by londonwhite » Thu Jan 15, 2026 2:21 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 8 Replies
- 10649 Views
Last post by deickos
Sat Apr 04, 2026 11:32 am
FHD IPS for T520
by TP_ » Mon Feb 16, 2026 1:25 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 3 Replies
- 6547 Views
Last post by dcfbf
Mon Feb 16, 2026 3:41 pm
Users browsing this forum: No registered users and 51 guests
