Blinking Lights on T430s
T430-T495, T530-T590 Series
Anthony_Queen
#1 Post by Anthony_Queen » Fri Sep 05, 2025 6:22 am
Hello, yesterday I decided to open up my ThinkPad to clean it and maybe install Usb-C PD in it (which in the end I didn’t do, since the module was too big), but now it doesn’t power on, the only sign of life I see is when I plug in the charger, and the battery LED blinks in this pattern: 4 blinks (stops for a bit at the fourth one) and then one blink.
What should I do? I already tried removing RAM, putting only one in, different slots, resetting CMOS by pressing the power button for 30 seconds, plugging the charger in without battery etc etc…
:help:
Anthony_Queen
Re: Blinking Lights on T430s
#2 Post by Anthony_Queen » Fri Sep 05, 2025 9:13 am
Fixed it!
For anyone wondering, if nothing works it’s probably the touchpad’s connector (the one in the center, just above the trackpad), I removed it and was able to enter POST, but I’ll have to replace it soon, since without it some of the keys on my keyboard stopped working (like Enter, Esc, Backspace, Cancel and the H key).
#3 Post by axur-delmeria » Sat Sep 06, 2025 7:13 am
You mean that the touchpad is somehow causing an electrical fault that prevents the laptop from powering up? That's new, but not implausible.
