I'm currently attempting some upgrades on a Z61p machine. I needed the ExpressCard socket for an eGPU purpose, which had a USB 3.0 + eSATA port adapter in it. I've also swapped the internal WiFi card for a USB 3.0 PCIe card, and then ran a short extension cable through the back with a socket on; this does not work/undetected by Windows XP. This was to free up my ExpressCard slot for my eGPU card and adapter.
I tried a few graphics cards plugged into a BEAST v8.5c eGPU host adapter, including an old desktop Geforce GTX550-Ti, to fully DSP power a convolution reverb plugin. https://gpuimpulsereverb.de/. This did not work no matter what BIOS display settings I used, or when I powered it up (pre / post Windows booted). I tried a GeForce GT610 again with no card detected by Windows XP Pro SP3 32-bit. I tried an ATi HD6570 card and that worked, but sadly it messed up the existing drivers used with the integrated FireGL v5200 GPU chip of the Thinkpad. I then decided to try my Thinkpad T43p and both the GeForce cards worked fine in the same BEAST eGPU adapter in the ExpressCard socket, Win XP etc. I did not bother trying the ATi card as the T43p also has an onboard ATi GPU chip.
So I am wondering what is causing the Z61p to not recognise the GeForce cards? I thought it might be that the T43p has 2GB RAM and the Z61p has 3GB RAM, but the ATi card worked with 3GB so not sure this is the issue.
Anyone any ideas as to why the same setup works with the older Thinkpad T43p and not the slightly newer Z61p? Can the discrete ATI Mobility FIREGL V5200 chip be disabled at hardware level?
Getting BEAST v8.5c eGPU + GeForce Cards To Work With Z61p ExpressCard Socket
Shredder11
W520 (C2Q i7-2720QM, 32GB, 240GB SSD)
X61 (C2D T7500, 4GB, 250GB SSD, BCM70015)
X61s (3GB, 120GB SSD)
T43p (PM 760, 2GB, IBM Port Replicator II, 128GB SSD)
G41 (P4 3.46GHz, 2GB, 128GB SSD)
Looking for a Geforce FX Go5200 for IBM ThinkPad G41
by LongJohn995 » Wed Apr 01, 2026 7:23 pm » in ThinkPad R, A, G and Z Series - 2 Replies
- 489 Views
Last post by LongJohn995
Thu Apr 02, 2026 2:24 pm
P15 gen1 ... will a 1TB + 4TB NVMe SSD pairing work?
by portsample » Thu Nov 27, 2025 8:23 pm » in ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series - 2 Replies
- 7592 Views
Last post by portsample
Thu Nov 27, 2025 10:00 pm
- 10 Replies
- 9722 Views
Sun Dec 21, 2025 4:38 pm
T470S suddenly stopped booting. Screen keeps black while everything else seems to work
by irock » Sat Feb 28, 2026 2:34 pm » in ThinkPad T430-T495 / T530-T590 Series - 9 Replies
- 4774 Views
Last post by irock
Mon Mar 16, 2026 12:57 pm
