Scorpion8
#1 Post by Scorpion8 » Thu Oct 23, 2025 9:40 pm
Doing some work on resurrecting yet another X1 Carbon. This one is a 4th Gen i5 - 8GB model. The previous owner broke out completely the Wifi card socket (sheesh, some people). I had a new spare mobo, so installed that, ran all the updates (repeatedly) and it's working fine (almost). Here's the issue and another question.
The issue is the keyboard works fine, except for the numbers row. And sometimes the Fn keys. For example, making changes in BIOS I cannot use F10 to save and reboot, but once the computer is up and running, the Fn keys work fine for their assigned task (volume, wifi on/off, etc). And then none of the number keys work. Odd sort of divisions in what works and what doesn't. I've tried reseating the cables. No joy. There doesn't appear to be sugar/syrup/drink debris, so..... thoughts? New cable? Doesn't appear to be pinched or broken anywhere.
And the general question: The UG and HMM both talk about replacing the mobo you need to re-establish the machine number, and it gives you a website for the software tool and then says "Only a Lenovo Technician can access this". The machine runs fine, the new mobo has it's own unique serial number. Is it truly important to re-establish what it was before the hardware swap? Neither (old or new) will be in-warranty so am not concerned about that.
T490/495/E14 and X1 Carbon user.
Pain heals, chicks dig scars, glory .... lasts forever.
Re: X1 Carbon 4th Gen -- Wonky Keyboard
#2 Post by RealBlackStuff » Fri Oct 24, 2025 1:26 am
Download the HMD: https://download.lenovo.com/ibmdl/pub/p ... tm38us.exe and install it temporarily on the laptop.
Plug in an empty small USB-stick (32-64MB is enough).
In the downloaded files is a program usbfmtpw.exe, run that to make a "Maintenance key".
Cold-boot the X1 from that to enter the old Model and S/N.
Scorpion8
#3 Post by Scorpion8 » Fri Oct 24, 2025 10:50 am
Thanks for that info, which I d/l'ed. But is it necessary for any reason? What does re-establishing the old serial number do for me that just using the new serial number doesn't?
#4 Post by RealBlackStuff » Fri Oct 24, 2025 10:58 am
If you want to run Lenovo updates, they won't work without that info.
It is the Lenovo MTM and S/N which is important, not the mobo S/N.
Scorpion8
#5 Post by Scorpion8 » Fri Oct 24, 2025 2:04 pm
Odd, because Vantage updates have worked fine. I even registered the unit on Lenovo's website and it recognizes the new serial # and system type (20FB) just fine.
Any thoughts on the keyboard issue? Odd that it affects just a single row of keys, and the entire row, not individual keys.
#6 Post by RealBlackStuff » Sat Oct 25, 2025 12:28 am
You wrote: "I had a new spare mobo", but maybe that was a used mobo?
Because brand new ones do NOT have their MTM and S/N on it.
Go here and enter the new S/N without a dash.
What info do you get?
As for the keyboard, either a spill on the KB, dirt in the KB-cable socket or a KB gone bad.
Scorpion8
#7 Post by Scorpion8 » Sat Oct 25, 2025 11:27 am
I get this and a list of all the parts just like my other X1's.... The replacement mobo (this s/n shown) was "new" from a Chinese eBay seller. It did not show signs of installation. Popped it in, hooked it up and it fired up first time.
#8 Post by RealBlackStuff » Sat Oct 25, 2025 11:42 am
OK, so your mobo already had an S/N when you got it, unusual, but hey...
As for the KB, replace it, or try if a KB from another X1C works.
Scorpion8
#9 Post by Scorpion8 » Mon Oct 27, 2025 12:49 pm
I cleaned the ribbon connectors and sockets on motherboard with IPA, with no change. I did not access the connections under the motherboard. No change. The odd issue is that F1 works fine to access the BIOS during boot, but F10 does not while "in" BIOS. And then none of the number keys (and only the number keys) don't work. Perhaps time to source a new keyboard.
Scorpion8
#10 Post by Scorpion8 » Wed Nov 19, 2025 4:42 pm
As a follow-up, I replaced the entire keyboard/palmrest with a eBay find, same model/FRU#. Works fine now, so somewhere in the old keyboard was the house of wonkiness. Got myself another nice running small laptop.
