W530 motherboard in W520 chassis?
alalalalysa
#1 Post by alalalalysa » Fri Nov 21, 2025 5:16 am
Fried W520 motherboard. Considering getting a W530 board and an i7-3632 to replace it (better GPU, CPU has lower TDP). Does anyone have any experience with this? Does it fit? What modifications are required? I know I'll have to flash the EC to get the keyboard to work properly and I know that the DisplayPort and eSATA+USB have been replaced with mini DP and just USB respectively.
moofish2842 on Reddit posted that they put a T530 board into a T520 and mentioned that the frame required a lot of modification but never elaborated. Their account is banned and I have no way of contacting them.
Re: W530 motherboard in W520 chassis?
#2 Post by RealBlackStuff » Fri Nov 21, 2025 7:43 am
T520/W520 have the same chassis, as do the T530/W530.
So you'd run into the same problems as this Moofish.
dcfbf
#3 Post by dcfbf » Fri Nov 21, 2025 11:30 am
From what I know, many of the standoffs are in the wrong places so you'll need to modify them and you'll have to live with most of the screws not put in.
Edit: the VGA connector is also different on the W530 compared to the W520
Current Dailies: X1C6, P71
Users browsing this forum: No registered users and 95 guests
