IBM ThinkPad z61m 4 cycles of 4 beeps.
Vasyu_06
#1 Post by Vasyu_06 » Mon Jan 19, 2026 2:07 am
Hello, I have an old thinkpad(z61m), that has worked before, that beeps 4x4 times. The main battery is dead. In the manual I found out that it is a system board(security chip) issue. The cmos battery - CR2032-BV1(LF) is also dead(o.o3v). It has 2x1gb ram configuration. How do i start with troubleshooting?
Re: IBM ThinkPad z61m 4 cycles of 4 beeps.
#2 Post by RealBlackStuff » Mon Jan 19, 2026 6:23 am
Welcome to the Forum.
Begin with replacing the CMOS battery.
Vasyu_06
#3 Post by Vasyu_06 » Fri Jan 23, 2026 3:50 pm
Can I solder the 2 wires to a normal cr2032 battery and replace the original one? In asking because locally cmos batteries with wires are extremely expensive.
#4 Post by RealBlackStuff » Sat Jan 24, 2026 4:56 am
NO SOLDERING!
This will help: https://writerit.nl/hardware/cmos/repla ... batteries/
That website says: Now wiggle the connectors until the metal breaks...
Instead I suggest: use some pliers to tear the whole metal strip off, if you can. Don't break the wires!
Vasyu_06
#5 Post by Vasyu_06 » Thu Jan 29, 2026 5:28 am
Ok, i will do it this way and will report back
Users browsing this forum: No registered users and 54 guests
