P14s soldered RAM timings
P1/P14/P15/P16/P40/P50/P70 Series
usescomputers
#1 Post by usescomputers » Sat Jan 24, 2026 3:45 am
Does anyone know the timings of the stock (soldered) RAM in the P14s Gen 3 (Intel) (21AK)?
i have 16GB (a Samsung M471A2G44BM0-CWE).
The goal of adding more RAM is to enable the Iris Xe iGPU and its Xe Linux driver. Currently, i can only utilise the i915 driver because of the soldered RAM's 64-bit single-channel. Intel requires RAM to be dual-channel and 128-bit to use the Xe driver.
As far as i understand, i need to match the capacity (16GB), frequency (3200MHz/MTz) and timings (i don't know).
dcfbf
Re: P14s soldered RAM timings
#2 Post by dcfbf » Sat Jan 24, 2026 2:28 pm
You can check using software like HWinfo
Current Dailies: X1C6, P71
Return to “ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series”
