Hi Guys - been a while since I was on the forum - might be back in 2012 when I got some amazing help and parts to keep some T61/T61ps going.... Haven't needed any guidance since then as, while I have been on Thinkpads every day since then they simply haven't gone wrong (fingers crossed and patting the x1 yoga I am writing on right now)...until now, so I thought I would see if I can pick collective brain on this matter.
Back in those days we had no kids...bliss...and now we have teenagers and one of them has broken the screen on his X13 Gen 1. I got a new screen, correct part number and so on and watched some videos on the swap which turned out to be wrong and I didn't disconnect battery and so have blown the backlight fuse, I am sure - symptoms are all there - machine works fine on second screen, new screen works too but very, very dark indeed and only really visible with a very bright light.
We have taken out the mother board in search of the fuse which we are expecting to be labelled F3 or 7 or 9 or something similar but can't see anything at all like that on either the front near the board connector or on the back at the same place and so, my question is:
Does anyone know which fuse is the backlight one? Any idea of number of position would be really very helpful indeed, can't see, for example, the fuse with the letter 'p' on it although can see one with an 'f' - I think we are in the vicinity but there are a number of possibles right around there.
Sure you guys know about it - nothing seemed to escape answer back in the good old days!
Warmest regards and thanks - Matt
X13 Gen 1 Backlight Fuse
X61s screen backlight doesn't work. Faulty mobo?
by huohuo » Tue Mar 03, 2026 6:35 pm » in Thinkpad X60/X61 Series incl. Tablets - 4 Replies
- 2565 Views
Last post by huohuo
Sat Apr 04, 2026 3:43 pm
SXGA+ led backlight broke, which path to take
by huohuo » Wed Apr 15, 2026 7:18 am » in Thinkpad X60/X61 Series incl. Tablets - 4 Replies
- 379 Views
Last post by huohuo
Wed Apr 15, 2026 3:27 pm
- 13157 Views
Last post by Scorpion8
Wed Nov 19, 2025 4:42 pm
T14 Gen 3 compatible 40-pin 4-lane display cables
by LimesKey » Fri Oct 24, 2025 3:22 pm » in Thinkpad T14/T15/T16 - 3 Replies
- 8143 Views
Sun Oct 26, 2025 12:57 am
