resizing pics
Got a question or suggestion about the forum? Ask or comment here, or
PM an admin or moderator.
Marin85
resizing pics
#1 Post by Marin85 » Sun Nov 08, 2009 8:46 pm
I would like to ask for some advice how to resize pics in order to prevent horizontal scrolling in the forum. I have 15.4'' WUXGA screen on my ThinkPad and whenever I take a desktop screenshot or even only a partial screenshot with the snipping tool or export some office or pdf document as a pic, it appears quite huge in the post. For instance, I posted some table from excel: I converted the excel file to .pdf with settings for minimal storage size of the pdf file, then I cropped all the blank spaces out of the pdf and then exported the pdf as a .tiff image. All in all just under 7KB, nevertheless the image appears huge. When I tried to resize the .tiff image using paint, its storage size grew over 100 KB... So, my question is this: Is there anything that can be done to reduce the optical size of the image, yet keeping it under 56KB, so that I can embed the image in the forum?
GomJabbar
Re: resizing pics
#2 Post by GomJabbar » Sun Nov 08, 2009 9:19 pm
If you host the image at http://www.imageshack.us/ there is an option before you upload to resize the image to a smaller optical size.
DKB
Marin85
Re: resizing pics
#3 Post by Marin85 » Sun Nov 08, 2009 9:50 pm
Ah true, great! Thanks a lot, Gom! That worked.
EDIT: I spoke too early. I tested this in my last post (the antivirus comparison) and when I checked the image size, it is now over 200 KB :(
Re: resizing pics
#4 Post by RealBlackStuff » Sun Nov 08, 2009 9:58 pm
Using the popular Irfanview, it has many options to resize a picture. http://www.irfanview.com/
Marin85
Re: resizing pics
#5 Post by Marin85 » Sun Nov 08, 2009 10:11 pm
Indeed, I photoshopped it a bit and the trick turned out to be resizing the image without resampling it. Of course, it is not the same quality, but it is still readable.
Thanks,
Marin
JaneL
Re: resizing pics
#6 Post by JaneL » Sun Nov 08, 2009 10:18 pm
Marin85 wrote:I would like to ask for some advice how to resize pics in order to prevent horizontal scrolling in the forum.
Post a link instead.
Jane
I'm on Twitter
Marin85
Re: resizing pics
#7 Post by Marin85 » Sun Nov 08, 2009 11:12 pm
JaneL wrote:Post a link instead.
Well, yes, that is the easiest way, but that was not the point. If it was, I wouldn´t have asked, would I.
JaneL
Re: resizing pics
#8 Post by JaneL » Sun Nov 08, 2009 11:16 pm
Marin85 wrote:Well, yes, that is the easiest way, but that was not the point. If it was, I wouldn´t have asked, would I.
<quirks brow>
You're feeling your oats tonight, aren't you?
Jane
I'm on Twitter
lexicon
Re: resizing pics
#9 Post by lexicon » Fri Nov 13, 2009 9:31 am
I'm using Photoshop to change Image size (Ctrl+Alt+I)
And Save for Web to adjust the compression (Shift+Ctrl+Alt+S)
T60p[2.0/4G/MomentusXT/ABG/UXGA/W7]
Past:701c T23 T4 T6 X3 X4 X6s
Return to “Forum Notices, Questions and Suggestions”
