10.6.3 on T60 1951CTO
Most of the hardware works, problem it is graphic card, with GMA950 27a2, it only supports the external monitor to display, which keeps the laptop's lcd black, I have read someone have fixed this using dsdt which I do not know how and what the code to change, anyone who know how to do this dsdt?
Re: 10.6.3 on T60 1951CTO
Have a look here (this was for X60 series with an Intel GMA950 ...)
Lenovo X60t (6363-AQ8)
- Intel CoreDuo 1,67 GHz (L2400)
- 3 Go / 320 Go / GMA950 / FW 400 / SD Card
- Bluetooth / Wifi AR5BXB6 / Tablet
Thank you. The GMA950 EFI fix the problem.
Other problem I am facing is I put VoodooHDA 0.2.6 under Extra/Extensions and sound is not working, and my wifi is atheros 5424, and it is not working.
The sound problem is fixed by the Kext Helper, use Kext Helper b7 to install the voodooHDA 0.26 and install VOODOOHDA prefpane.
Only problem is wifi doesn't work, card is Atheros 5424.
Have a look here for Atheros Legacy kext ... Edit the plist and modify the id with this one, and put it in /Extra/Extensions/
id:
Repair Permission and rebuild kext cache (... or just simply run pfix !)
Reboot ...
id:
<string>pci168c,1014</string>Reboot ...
It fixed the problem, Just put the AtherosFix.kext under /Extra/Extensions/ and reboot it works. Only touchpad the trackpoint do not work.
For trackpad and trackpoint use VoodooPS2 linked in the last post here: http://forum.thinkpads.com/viewtopic.php?f=32&t=86059afcn007 wrote:It fixed the problem, Just put the AtherosFix.kext under /Extra/Extensions/ and reboot it works. Only touchpad the trackpoint do not work.
Intel Core 2 Duo T7600
That fixed the problem, but I need to use kext helper to install the voodoops2 and ultranav drv.
Only right now the sleep does not work. Seems it relates to the voodoops2.
Download pfix and run in once, it will generate proper kext caches for you.afcn007 wrote:That fixed the problem, but I need to use kext helper to install the voodoops2 and ultranav drv.
What is your sleep problem? If you cannon wake up, than it's audio related problem, most probably VoodooHDA related. If your screen is not shutting off, that it's video driver problem. VoodooPS2 cannot break sleep.
Actually it does on my X60t ... and so does VoodooHDA ... But sleep is a very tricky issue : I guess every config has its own sleep issues depending on the hardware and the software solution used to make it work ...Silencer wrote:VoodooPS2 cannot break sleep.
I have upgrade from 10.6.4 to 10.6.6, I found when reboot, it stop at the Atheros5424 driver, and a cpu panic, if I disable the wifi in bios, I can boot successfully with 10.6.6 all works well except the wifi, any ideas?
Wifi support (Atheros) changed during 10.6.5 update. Check here to see what we did to recover wifi : http://forum.thinkpads.com/viewtopic.ph ... &start=194afcn007 wrote:I have upgrade from 10.6.4 to 10.6.6, I found when reboot, it stop at the Atheros5424 driver, and a cpu panic, if I disable the wifi in bios, I can boot successfully with 10.6.6 all works well except the wifi, any ideas?
IBM T60 and Lenovo T60, dimmed screen when on battery?
by TP_ » Fri Feb 20, 2026 8:32 am » in ThinkPad T60/T61 Series - 3 Replies
- 3703 Views
Last post by TP_
Sun Feb 22, 2026 1:05 am
WTB: UXGA IPS Flexview for T60
by cowsay » Fri Oct 24, 2025 9:08 am » in Marketplace - Forum Members only - 1 Replies
- 5313 Views
Last post by Medessec
Fri Oct 24, 2025 10:49 am
WTB: T60/T60p 15” palm rest and keyboard bezel
by stanleylieber » Fri Oct 31, 2025 4:32 pm » in Marketplace - Forum Members only - 3 Replies
- 6641 Views
Last post by KAQSP
Thu Nov 20, 2025 6:33 pm
T60/T61 RAM Compatibility Question with DDR2 Modules Above 2GB
by annawonka » Wed Nov 12, 2025 11:43 pm » in ThinkPad T60/T61 Series - 2 Replies
- 7937 Views
Last post by Glaurung-quena
Thu Nov 13, 2025 2:37 pm
Users browsing this forum: No registered users and 59 guests
