p50 / *BSD
P1/P14/P15/P16/P40/P50/P70 Series
ralphee
p50 / *BSD
#1 Post by ralphee » Sun Jan 13, 2019 5:45 am
anyone running *BSD on their p50? was looking to try OpenBSD in particular but with Nvidia Optimus i am doubtful....if you are running a *BSD on your P50 please tell me more about your experiences good & bad...
tlavoie
Re: p50 / *BSD
#2 Post by tlavoie » Mon Mar 18, 2019 4:56 am
I haven't tried, but you can probably try a live-"CD" session with whatever bootable install media is available. (At least, that's common elsewhere like Linux distros.)
unix_joe
Re: p50 / *BSD
#3 Post by unix_joe » Sun Apr 21, 2019 12:52 pm
I have run OpenBSD on a W530, P70, and currently P71 with no issue. You should be fine.
As long as it has integrated graphics as an option, OpenBSD will roll to that. There is no nvidia support since 2007 or so.
External monitors will likely not work as they are driven by the nvidia chip.
unix_joe
T14 Gen 1 and some older ThinkPads running Debian.
ralphee
Re: p50 / *BSD
#4 Post by ralphee » Mon May 06, 2019 2:06 pm
how is your battery life on the p70....i can only get max 4hrs on openbsd (compared to 10 hrs on linux) with screen brightness set @ 30% and apmd set to auto
unix_joe
Re: p50 / *BSD
#5 Post by unix_joe » Sun May 12, 2019 2:49 pm
I really don't know how battery life is. I am usually plugged in. Maybe once a month I'll go sit on the couch, and that's not more than 30 minutes at a time.
unix_joe
Return to “ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series”
