P71 STOPS BOOTUP AT LENOVO RED SCREEN
P1/P14/P15/P16/P40/P50/P70 Series
LEMONDROP9344
#1 Post by LEMONDROP9344 » Wed May 29, 2019 10:14 am
P71 fails to boot up. Stops at screen display red Lenovo logo with message 'To interrupt normal startup, press Enter'. Pressing enter does nothing. Have tried PF12, have tried booting up without battery installed & battery only. Device was working fine when last used. Placed laptop in case & then into back pack. Return to house & attempted to use laptop and it's just stops at this point.
Laptop is out of warranty. I'm looking for suggestions on how to proceed in trouble shooting this issue, or, if someone has encountered & resolved a similar problem.
Any help would be appreciated. Thank you.
MikalE
Re: P71 STOPS BOOTUP AT LENOVO RED SCREEN
#2 Post by MikalE » Wed May 29, 2019 11:08 am
Was the computer hibernating or asleep when placed in your backpack?
Have you tried re-seating the memory?
Any beeps at POST?
A31p P-IV 2Ghz, 2MB, 2653-R6U
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T16 i7 1260P 21BV000SUS
LEMONDROP9344
#3 Post by LEMONDROP9344 » Wed May 29, 2019 4:41 pm
I will reseat the memory.
I normally go through a process where I shut the PC down (habit) prior to putting it in the back pack. I have to assume I did it this time.
There are no beeps.
Will report back after reseating the memory.
LEMONDROP9344
#4 Post by LEMONDROP9344 » Wed May 29, 2019 5:47 pm
Opened up the laptop. The 16gb memory module is secured with a screw. At any rate, I removed it and reinserted the module. Same results, stops at Lenovo red screen logo. No beeps, pressing enter does nothing, PF12 does nothing.
Any other ideas suggestions>
w0qj
#5 Post by w0qj » Thu May 30, 2019 1:47 am
Sounds like a faulty Motherboard to me, since you cannot even get into the BIOS...
1. As a last resort (and a looonng shot), try reseating your SSD as well.
Good luck!
LEMONDROP9344
#6 Post by LEMONDROP9344 » Thu May 30, 2019 9:02 am
Thought I would post the solution to this issue. It came from the Lenovo forum.
Their suggestion was to remove any connected external devices. For over a year and a half, I've had a USB mouse dongle plugged into the P71. I started to reply there were no external devices attached, but, them remembered the USB dongle. I removed it & the P71 came up with the Lenovo red screen logo. I pressed enter & voila..... IT'S ALIVE!
Thanks for the suggestions & help. :D :D :D :D :D :D
w0qj
#7 Post by w0qj » Fri May 31, 2019 12:20 am
Thanks for your sharing ;)
...Lenovo forum.
...I removed it & the P71 came up with the Lenovo red screen logo. I pressed enter & voila..... IT'S ALIVE!
Return to “ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series”
