Carbon X1 4th Gen & External Monitors
terrain_inconnu
#1 Post by terrain_inconnu » Fri Jan 31, 2020 10:43 am
How many external monitors can I connect to a Carbon X1 4th Gen without using a docking station and assuming that the internal display will be deactivated? I am interested in connecting 3 external 1920*1080 monitors via DisplayPort (daisy chain). Is that possible?
w0qj
Re: Carbon X1 4th Gen & External Monitors
#2 Post by w0qj » Fri Jan 31, 2020 12:17 pm
Our X1C4 had only 1 external monitor connected (via HDMI).
Anyone else have actual experience for OP's proposed setup?
BillMorrow
*Senior* Admin
*Senior* Admin
#3 Post by BillMorrow » Fri Jan 31, 2020 12:38 pm
hello and welcome to the forum..
interesting question..
my GUESS is YES if you want to wind up with the SAME duplicate display on each monitor..
[got to run now, i'll come back later for my T40 series 3 monitor setup]
Sysop - forum.thinkpads.com
~~~Mark Twain~~~
terrain_inconnu
#4 Post by terrain_inconnu » Fri Jan 31, 2020 12:46 pm
Why duplicate? According to the specs (https://images-na.ssl-images-amazon.com ... yOECmL.pdf) the Intel HD Graphics 520 supports 3 independent displays.
SurrealMustard
3 Monitors
#5 Post by SurrealMustard » Fri Apr 03, 2020 9:09 pm
I can say from experience that the maximum on the 4th generation X1 Carbon is 3 monitors, however, one of those monitors has to be the built-in display. According to Intel's official support bulletin, you could also probably get 3 independent external displays going, (without the laptop screen) but only if two of them were native DisplayPort. I haven't tested the 3 external display solution myself, so that'd be up to you to test.
