Hello to everyone.
First of all, forgive my English since it's not my mother tongue. I am using my trusty ThinkPad x260 as my daily driver.
My issue is that in the last couple of days I saw that the power button light indicator is off, while my laptop is working fine and boots.
Also, the red dot in the lid is not working when I plug my charger or when I close the lid (sleep mode).
I removed the battery external and internal and pressed the power button for 30 seconds, but no luck. I also removed CMOS battery but again no luck. Furthermore, emergency reset hole and setting bios to default settings didn’t work either. Rolled back to a previous bios version but again no luck.
Any ideas?
Thanks for your time, Good day.
Thinkpad x260 indicator lights not working.
Re: Thinkpad x260 indicator lights not working.
Welcome to the forum.
It sounds like there may be a burnt fuse on the path that is feeding the indicator lights. I don't know where it might be, but hopefully somebody on the forums has more knowledge of the internals of these systems.
Thank you for the answer. I guess you're right. I also tried forcing the led light in power button goes on through linux terminal with: # echo on /proc/acpi/ibm/led but yea it's dead..
I will possibly disassemble and try to find the fuse (I guess near the power button). I will keep you updated
Thanks again.
Thanks again.
I checked the power button with a multimeter continuity and it works, light on when I touch the fuse.
So it's either the ribbon cable that connects the power button, the red dot in the lid and the camera at the same time or a fuse in the motherboard.
I will buy a new cable and replace. I will let you know. Thanks for your help.
https://ibb.co/vsSYTkn
- 3 Replies
- 5022 Views
Last post by dcfbf
Thu Jan 29, 2026 11:03 am
x230t display not working
by sleeping_nicodemus » Thu Dec 18, 2025 11:43 pm » in ThinkPad X230-X280 / X390 Series - 1 Replies
- 4805 Views
Fri Dec 19, 2025 7:01 am
- 10 Replies
- 10000 Views
Sun Dec 21, 2025 4:38 pm
Intel 3946ABG on my ThinkPad x131e is not being detected
by whitepainted » Mon Dec 15, 2025 9:23 am » in ThinkPad X100e/X120e/X130e/X140e Series - 2 Replies
- 4469 Views
Tue Dec 16, 2025 1:57 am
