Is T420 Died? [SOLVED]
hi guys, today i've had an issue with my t420. This laptop is with me from some years and i hadn't any kind of problems. Today, while i was working, it poweroff. I've tried to turn on but nothing. Not a sign, a sound or something else, even the power led doesn't turn on. Does someone have ever had the same problem?
n4b00
n4b00
theterminator93
Re: Is T420 Died?
Remove the battery, power cord, then hold the power button for 30-60 seconds. Release the power button, reinsert the AC adapter (but no battery) and see if it will power on.
The recovery sets guy
Re: Is T420 Died? [SOLVED]
Hi, many many thanks for your kind reply. The procedure that you suggested have fix the problem. Do you know what made this kind of error?theterminator93 wrote: ↑Mon Feb 12, 2024 6:19 pmRemove the battery, power cord, then hold the power button for 30-60 seconds. Release the power button, reinsert the AC adapter (but no battery) and see if it will power on.
theterminator93
Re: Is T420 Died?
Glad you're back up and running.
Without being able to reproduce the problem at will, it's hard to be sure. Hopefully it never comes back. If it does, I'd be initially suspicious of the battery itself causing issues (if it happens again, run it without battery for a while to see if the problem returns, and/or replace it)... or it could be a sign of a developing planar issue.
Yes, your help was very useful. Your answer was so accurate that I have thought that you had on mind a specific problem.
The battery should be original, do you think that power battery daemon on Debian 11 can generate this kind of problem?
However thanks again for the help and i hope that the problem never come again.
Virtualization on T420
by Berator » Sat Nov 22, 2025 10:25 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 3 Replies
- 6967 Views
Sun Nov 23, 2025 11:56 am
- 4 Replies
- 6982 Views
Last post by Kiriakos
Sun Feb 15, 2026 12:25 pm
by londonwhite » Thu Jan 15, 2026 2:21 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 8 Replies
- 10651 Views
Last post by deickos
Sat Apr 04, 2026 11:32 am
T420 Lid Sensor Trigger Location? (WARNING: PICS)
by T_B » Fri Jan 16, 2026 11:08 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 2 Replies
- 6649 Views
Last post by T_B
Mon Jan 19, 2026 11:24 pm
