Hey everyone,
I’m looking at two second-hand ThinkPads and could use some advice on which is the better deal. Here are the options:
Option 1:
ThinkPad T14 Gen 2 (Ryzen PRO 5650U)
40GB RAM, 512GB SSD for €400
Option 2:
ThinkPad X1 Extreme Gen 2 (i7-9750H, GTX 1650)
32GB RAM, 1TB SSD for €650
I’ll be using the laptop mostly for programming and daily tasks, but I’d also like to play some non-demanding games like League of Legends. I plan to use the laptop for at least 3 more years, so durability is important.
Which one do you think is more worth it and would last longer? Also, if you have any other ThinkPad model recommendations within my budget (max €700), feel free to suggest!
ThinkPad T14 Gen 2 or X1 Extreme Gen 2?
BillMorrow
- *Senior* Admin
Re: ThinkPad T14 Gen 2 or X1 Extreme Gen 2?
X1 extreme IF 16 inch 4K touch display..
i have 4 one i use all the time for years and the others are backups.. dusty backups so far..
otherwise season to YOUR taste..
Bill Morrow, kept by parrots
& cockatoos
Sysop - forum.thinkpads.com
~~~Mark Twain~~~
~~~Mark Twain~~~
So if it's just regular 4 k 15.6 I better choose T14? I looked that X1 with 4k tend to have battery problems ,but I mainly plan to use it with battery adapter mostly ,so it's not a big problem:/ .
T14. It's got a better CPU, more RAM and it's over 200 euro cheaper.
You can't push it on either so having the 1650 is a moot point.
T14 Gen 3 compatible 40-pin 4-lane display cables
by LimesKey » Fri Oct 24, 2025 3:22 pm » in Thinkpad T14/T15/T16 - 3 Replies
- 8215 Views
Sun Oct 26, 2025 12:57 am
T14 Gen 1 AMD - problems with wwan card: whitelist?
by piripuz » Mon Nov 17, 2025 4:42 am » in Thinkpad T14/T15/T16 - 4 Replies
- 10517 Views
Last post by piripuz
Wed Nov 19, 2025 5:56 am
- 5 Replies
- 10649 Views
Last post by Python.p
Mon Oct 27, 2025 3:57 am
Can I restore T14 Gen2 after reset using backup of SSD?
by Thinkpad2024 » Sat Nov 01, 2025 9:33 pm » in Thinkpad T14/T15/T16 - 4 Replies
- 8522 Views
Sun Nov 02, 2025 2:30 pm
Users browsing this forum: No registered users and 51 guests
